Filtering string data table based on certain date range
Hi all,
I need your help and advice. It's been long that I have used LV and currently doing some project for services planning.
I want to filter out a string table full of expected date for servicing with all the equipment data/descriptions based on month and year.
What is the best solution to do it? Do I need to extract each column from the 2D array and find all the index? Can you guys help me out?
Message 1 of 8
(5,488 Views)
Hi azh,
with the InRangeAndCoerce function you should not attach timestamp arrays to the upper/lower limit inputs: a scalar timestamp is sufficient!
And most probably you want to use the boolean "InRange?" output rather than the "coerced value" output:
Message 2 of 8
(5,461 Views)
Hi GerdW,
Thanks for your response and tips Smiley Wink. I already tried out finding all the indices that matches the "in range" section as attached. So I guess I have to extract all section in 2D array into 1D array (Next PM Date1, Date2...), filter it to the same range and build back the 2D array correct?
Regards.
Azh
Message 3 of 8
(5,409 Views)
Accepted by topic author azhwoony
What version of LV?
I'm assuming the arrays are the same length.
Bill
CLD
(Mid-Level minion.)
Message 4 of 8
(5,373 Views)
Hi Bill,
Thanks for the tips! It was helpful to simplify on getting the date and service in range.
Am using LV 2018 SP1
regards,
Azh
Message 5 of 8
(5,330 Views)
Guys,
There's been 1 issue when I tried to add up the date to the PM period. The problem is when I pull data from a text file and convert it to number, the date can no longer add up to the calculated period. However, when I simulate using new DBL control, it works. Can u advise? Attached as reference.
Message 6 of 8
(5,321 Views)
Hi azh,
The problem is the different display format of "PM freq (in days)" and "x*y (days)"!
"Date PM Array" is calculated correctly because you add days.
"Date PM Array 2" is wrong because you add seconds…
Message 7 of 8
(5,315 Views)
Thanks gerd. It solves all Smiley Very Happy x*y is just converting period in month to number of days. So i just times seconds to it.
Message 8 of 8
(5,306 Views)
