Find All Non-Programmatic Shared Variable Instances in LV Code
I inherited a large LV project with both Windows and RT targets.  This code base can be built and deployed to different test cells - each cell has a unique subnet that the RT and Windows apps talk to each other over.  The issue I have is that there are many Shared Variables in the code which do not use programmatic access and so they are tied to whichever test cell's IP address is currently specified for the RT target in the LV project.
This means if I want to update the application version running in each cell I have to first set the correct test cell IP address on the RT target in the LV project, open the windows exe build spec, click on Shared Variable Deployment, hit save, and then rebuild the code, and I have to do this for every test cell even though nothing in the actual logic has changed. This results in days of wasted time just building the same application over and over again, etc.
I can eventually convert all Shared Variables in the code to have programmatic access so they can load the IP address at runtime, i.e. a "build once, run anywhere" architecture.  But I am afraid that down the road someone will forget this best practice and drop a non-programmatic access SV onto a block diagram and cause difficult-to-debug runtime issues. Is it possible to write a script which finds all non-programmatic SV instances in a code base?  I would then trigger this script to run every build.
Perhaps there is another way to approach this problem. Any input appreciated.
(1,384 Views)
Accepted by topic author jvon24
Hi jvon24,
Here is a script that lists all VIs containing at least one Shared Variable Node.
You have to add the script to the project you want to analyze.
Raphaël.
(1,346 Views)
Excellent solution, and beautifully written. This has, and will, save me a lot of time.
One thing to note, for anyone else looking to use this, is that any errors that arise will cause the VI to terminate early (not really a bad thing), however, some of the below errors could be expected in a typical project for the snippet as written:
  • Error 1035 thrown by VI Scripting - Traverse.lvlib:Traverse for GObjects.vi for VIs with no block diagram (e.g. Global Variable FPs)
    • Can also be thrown when an unused file is in conflict on disk in an autopopulating folder.
  • Error 1040 thrown by VI Scripting - Traverse.lvlib:Traverse for GObjects.vi for VIs with password protection enabled
  • Error 1125 thrown when an analyzed VI is saved in a later version of LV. Obviously, a clean project (mine is not) with correct usage of autopopulating folders would not have this problem.
(1,263 Views)
