Find Examples dialog appears to have environment issues
Does anybody know why my Labview 2010 Environment is looking like the picture attached.  I have adjusted the environment settings (font), and it has not improved the Find Examples Dialog.  I also noticed something similar happening when I open a labview example.
(2,924 Views)
Accepted by topic author Boutros
Did you change your font settings in your operating system? Did you change the DPI setting in your operating system? Either of these can have the effect that you are seeing. If you didn't, then perhaps someone else did.
Did you change the fonts in the LabVIEW options? If you changed the fonts in the LabVIEW options try changing them back, or simply delete/move the LabVIEW.ini file so a clean one gets created.
(2,915 Views)
