Find Items with no Callers only ever shows 7 items?
I'm asking/post here before going to the Idea Exchange. But is there any reason why the Find Items with No Callers option in the project only ever shows 7 items even though there are many more? The screen even has scroll bars that are disabled. Is this a bug/error or is there some good reason it only shows 7 items at a time?
(3,623 Views)
Duke,
When I use this function, a list is returned with 10 visible items and a scroll bar.  What version of LabVIEW are you using? I am currently running LabVIEW 2010 SP1.
Zach C.
Field Engineer
Greater Los Angeles
(3,600 Views)
I'm also currently using Labview 10 SP1. I wonder if there is an option or line in the INI file that determines this...
(3,588 Views)
That is insteresting that you're not able to use a scroll bar to see additional items.  If you want to attach your current .ini file I'll take a look at it and look into this issue further.
Zach C.
Field Engineer
Greater Los Angeles
(3,572 Views)
I attached my INI file. I have no idea if the INI file controls anything like this, it was simply a suggestion. I would have no idea why else this would happen but reconfirmed today that I am limited to a few items and the scroll bar is never available to be used (even though the list is never longer than the original screen anyway).
(3,565 Views)
Accepted by topic author JonJay
Well it was a good suggestion to check the .ini file.  There is a token called "FindProjectItems.MaxResults=x" My .ini file had this value set to 2000 while yours was set to 7.  I tried changing mine to 7 and I saw the same behavior as you.  You should just need to increase this value in the .ini file, then restart LabVIEW.
Good luck!
Zach C.
Field Engineer
Greater Los Angeles
(3,556 Views)
Worked perfectly. I have no idea how it got set to 7 as I didnt even know such a token existed. Thanks for the help!
(3,548 Views)
