Find License Number in LabVIEW Program?
My name is Cleber, I'm from Brazil.
I'm trying to find a role in the programming of LabVIEW that I return the License Number and name of the User registered for this license. But so far failed. I thought as I return the type ofLabVIEW installed, but I need this information for my program is completed.
Can anyone help me?
Thank you.
Message 1 of 8
(5,715 Views)
Accepted by topic author Cknies
Is this what you're looking for?
Message 2 of 8
(5,692 Views)
Hello pcardinale,
How did you put in the property node the following properties:
App.SerialNo
App.RegOwner
App.RegOrg
I tried all ways to find these properties but could not find them in the properties of the App
I am very grateful.
Thank you.
Message 3 of 8
(5,665 Views)
Hello Cknies,
you can use the Class Browser (View\Class Browser). In the opened window, select:
Object Library: VI Server
Class: Application
Then click on Search Button. In the new window, look for properties which you need.
Best Regards,
Ricardo Ramos
Account Manager
+5511989658513 | ni.com
Message 4 of 8
(5,654 Views)
Well then, I still can not locate these properties. Does it have something to do with Labview version? I am using the 2011 Professional. But when I run the above program it works. I do not know what is happening. Can you help me?
Follow the screen attached.
Thank you
Message 5 of 8
(5,647 Views)
Hi Cknies,
If you don't find these properties, you can drag the properties in pcardinale' example to your VI.
Ricardo Ramos
Account Manager
Message 6 of 8
(5,638 Views)
Those properties are private. Add the following to labview.ini:
SuperPrivateScriptingFeatureVisible=True
SuperSecretPrivateSpecialStuff=True
Message 7 of 8
(5,627 Views)
Now I found the properties. Hehe. You know some more tips like this?
You know how I can to run a program on my computer to know the serial number of the LabVIEW of all the machines logged on the network? If you can help me of course.
Thank you.
Message 8 of 8
(5,610 Views)
