Find RTD inverse transfer function from Labview
RTD has transfer function, to calculate resistance from temperature as below:
R = R0( 1 + A*t + B*t*t + C(t-100)t*t*t )    for t <= 0C             .......equation 1
R = R0( 1 + A*t + B*t*t )                         for t >= 0C             .......equaion 2
Now I want to find inverse transfer function of it i.e calculate temperature from known resistance.
Now equation 2 is simple as it is quadratic & its inverse transfer function is easy to find.
But can I find inverse transfer function of equation 1 withh help of labview function.
(4,834 Views)
Hi AA,
as LabVIEW is a programming language you can certainly program a VI to do what you want.
You could calculate a lookup table for R=f(T). Then you use that lookup table to interpolate values for T=f(R). Or you create a polynomial interpolation to get T…
(4,810 Views)
Assuming you know the values of constants R0, A, B, C, you essentially have a polynomial equation in t and to get t from a known value of R, you need to find the roots of that polynomial. This can easily be done in LabVIEW by using the Polynomial Roots.vi (found under Mathematics > Polynomial on the functions palette. Since your polynomial is of 4th degree, you will get 4 roots. Since this equation is for negative temperature, you should look at the negative, real root of the polynomial equation.Find temp from Resistance.png
Chinmay Anand Misra
CLD
Technical Marketing Engineer
NI IndRA
(4,792 Views)
about 20 years ago I used the newton solver....
something like
The RTD conversion vi found under numerics-scaling doesn't cover 'correctly' temperatures below 0°C, however I never checked how big the differences are..
Greetings from Germany
Henrik
LV since v3.1
(4,776 Views)
