Find Reentrant VI in memory by VI server
Hi, in LabVIEW 2013 there is a new feature that help to open instance of reentrant VI:
Is it possible to do it by VI server?
I looked at the Properties and Method and I didn't find anything 😞
Anybody as achieve that with LabVIEW 2013?
LabVIEW ChampionArchitect
(2,958 Views)
Anyone at NI can confirm that it's possible or not?
(2,897 Views)
HI Dani
Identifying which VIs are reentrant and open them using the VI Server can’t be done.  What you can do is programmatically read the VI properties and detect which VIs are reentrant using a property node. This article shows a simple example to detect if a VI is reentrant or not.
Regards
Chris S.
(2,875 Views)
@chris88 wrote:
HI Dani
Regards
Ok thank you Chris
I will add a suggestion on the Ideas Exchange
(2,848 Views)
For those who want this Property in VI Server Please vote for this idea:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/List-of-clone-in-memory/idi-p/2639435
Thank you
(2,820 Views)
