Find a delay and avoid/remove it from a while loop
Can you post that SignalOutput.vi?  Since that is what is setting up your task.
Message 11 of 13
(822 Views)
Here it is, sorry
Message 12 of 13
(817 Views)
Accepted by topic author AnthSal
Ok, the SignalOutput.vi already has the regeneration mode in there.  Your problem now is the DAQmx Timing VI.  The Sample Mode is being set for Finite Samples.  You want it to be Continuous Samples.  And with that, you don't need to wire the Number of Samples to the DAQmx Timing either.
Message 13 of 13
(809 Views)
