Find an audio signal in a signal
im planning to build a project which have a referenced recorded signal.
i have a unit that produce an audio tone , this tone will be sampled and compared to the refernced signal.
i need to develop a code that finds if the sampled tone includes/similar to the referenced signal.
negelect the HW which is required, any idea how to start it ?
(2,740 Views)
Use a Fast Fourier Transform (FFT).  Take a FFT of your reference signal and then compare the FFT of your input signal to that.  It would be best to make the sampling rate and duration the same for both signals.
This is all I got unless you provide a little more detail on what you are trying to do.
Randall Pursley
(2,708 Views)
Agree with other comment.  Just do an FFT and see if the frequency component of the tone is there.
(2,695 Views)
If your tone is not continuous then try a short time Fourier transform or use a cross correlation in the time domain to find the time of your signal.
mcduff
(2,679 Views)
