Find and Read the Target Spreadsheet File from Target Folder
I'm trying to find and read the target spreadsheet file from the target folder. Please help. Thanks.
(3,915 Views)
What's your question?
What is it doing? What is it not doing?
We need more information.
(3,900 Views)
My question is how to find the target spreadsheet file from the folder that I'm looking for.
For example:
I have 2 different folders (folder A and folder B). In each folder, there are 3 files (file 1, file 2, file 3). I want to point to the target folder and call out the file that I want to read.
(3,892 Views)
Use the File Dialog Express VI?
(3,888 Views)
It worked, but I do not like the popup everytime. Any idea how to make it automatic? Thanks
(3,877 Views)
If you know the folder, you could do a List Folder Contents to get a list of files in that folder.  You can then just use Array Index to get the file you want.
(3,873 Views)
Accepted by topic author CP_AT
Build Path VI will solve the problem.
(3,856 Views)
