Find and edit specific line in text file?
The code now changed a litte i i now want to do the same thing as in my last post but i want to make the changes in a text file,
Message 11 of 12
(937 Views)
What version are you using?  You can still use the FOR loop.  You will just have to keep your new array in a shift register and use Build Array inside of a case structure to choose when to add the elements.
As for doing with a file, go read the first sentence of message 4 in this thread...
Message 12 of 12
(930 Views)
