Find and replace butchers numeric constants
In a few words.
This only seams to happen if the block diagram is behind another pane when the replacement is made.
LabVIEW 2012f3 Win7 (Yes, Aveo theme)
(4,007 Views)
Hi Jeff,
Thanks so much for bringing this bug to our attention. I was able to reproduce this on my machine as well. I will make sure that a bug report is filed on this issue. I'm sure you've already discovered this, but in the mean time you can just do this search and replace with the block diagram in view. Thanks again.
Michelle G
Applications Engineering
(3,949 Views)
@Michelle_G wrote:
Hi Jeff,
The better work around is to "code it once" Smiley Very Happy  What are all those same numeric constants doing on all those block diagrams?  Let me know the CAR when you file it.
(3,931 Views)
Hi Jeff,
The CAR number is 402822. Once again, thanks for bringing this to my attention.
Michelle G
(3,895 Views)
