Find callbacks in several sequence files
We have a lot of tests in which we must search if the overwrite the preUUT callback.
I want to use teststand to load a test and search if that test overwrites the preUUT callback.
Is this possible?
(2,591 Views)
Accepted by topic author InspectorGadget123123
You can use the method: RunState.Engine.GetSequenceFile("NAME OF SEQUENCE").SequenceNameExists("PreUUT")
I tested it by using the expression: Locals.Exists = RunState.Engine.GetSequenceFile("NAME OF SEQUENCE").SequenceNameExists("PreUUT")
to set a variable called Exists to true or false depending on whether the PreUUT callback had been changed or not.
(2,505 Views)
Hi AlasdairMee,
Thank you for your reply.
I had some problems finding which reference to use, I had some exaples which use this context but below you can see that I use the reference 'Teststand  UI...'.
Find myself a bit of a noob but it's solved.
(2,489 Views)
