Find difference between two numbers (DBL)
Gaurav,
I wish you all success!!!
Davidson
Message 11 of 16
(3,916 Views)
I think using the work "difference" is not clear.  What would you expect as an output for the "difference" between (-5) and (-1)?  (+4)?  Are you looking for the magnitude and direction of motion along a number line from the first number to the second?
Jim
Message 12 of 16
(3,906 Views)
You are right. The naming difference is confusing.
I would require it to be (-4).
In a way i would require the direction of motion from max to min. ie) i assumed my first number should be always max.
Thank,
Davidson
Message 13 of 16
(3,895 Views)
So, you want the magnitude and direction of travel from Max to Min?  That'll always be the negative of the absolute difference.  No?
Jim
Message 14 of 16
(3,888 Views)
Accepted by topic author Davidson_D
@davidson D wrote:
[...] ie) i assumed my first number should be always max.
It's easier if you know your first number is always larger.
Jim
Message 15 of 16
(3,869 Views)
Jim,
Thank you very much for the help.
I really appreciate the active replies 🙂
Davidson
Message 16 of 16
(3,849 Views)
