Find files by date determined
I want get files by date determined.
Such as I will select date wanted to read files in that day.
(1,703 Views)
Hi Waruntron,
And what is the (exact) question?
What have you tried and where are you stuck?
You can get a list of all file in a folder and determine their properties (like creation date). Based on that information you can filter the list to select your files…
Edit:
In your first thread you gave atleast an example VI, but forgot to mention the actual solution. Now you also forgot that example VI…
(1,665 Views)
Use a List Folder to get all files. Then, for each file get the last mod data. Use the date.
Or (if you want to make your life easy), save the files with the date\time in the names. Use the pattern to filter the files.
(1,647 Views)
