Find from 1D array and build new one
hey...im quite new in LV..
My "big"Smiley Sad problem is:
I have 1D array of numbers :
  • 10
  • 10
  • 20
  • 20
  • 20
  • 10
  • 10
  • 30
  • 45
  • 10
  • 10
and i wanna build and collect numbers in new 1D array
Like this:
  • 10
  • 20
  • 30
  • 45
Tnx so much 🙂
Message 1 of 13
(3,756 Views)
So essentially, you want to remove redundant elements?
Norbert
EDIT: What data type are your elements? If they are integer, it is rather simple.
Norbert
Expert: Geometry
Message 2 of 13
(3,755 Views)
Yes i wanna remove redundant elements.
My data type is "double".
tnx
Message 3 of 13
(3,751 Views)
The simplest solution is often the best. You need to sort the array first then check if the current value is same as previous, if so, don't add.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
Message 4 of 13
(3,733 Views)
That solution is good unless they want to keep the original order.  To keep the original order, you need to use the Search 1D Array to see if the current element has a duplicate.  If it does, delete the duplicate.  Perform the search again until no duplicates are found.  Then do the same operation with the next element.
Message 5 of 13
(3,730 Views)
So, you suggest more of this:
Message 6 of 13
(3,726 Views)
I suggest to be aware of issues with comparing floating point numbers with "equal" or "not equal"!
Norbert
Norbert
Expert: Geometry
Message 7 of 13
(3,722 Views)
Accepted by topic author ant_inter
"The simplest solution is often the best"
Smiley Very Happy
Message 8 of 13
(3,713 Views)
Smiley Very Happy
I think Don has us beat.  Oh the things you can find if you take the time to dig around...
Message 9 of 13
(3,699 Views)
hey...super...it works...tnx to all 🙂
tnx again 🙂
Message 10 of 13
(3,664 Views)
