Find highest value in an array (or cluster)
I have what should be a simple task here, but I'm not finding it simple, or shall I say, "small" insofar as diagram objects. Task is: Find highest value in an array of numbers. Is there a function or VI I'm not aware of that'll do this? If not, could someone demonstrate a small vi that does this? Thanks
 p.s., my array has 12 numbers. It's actually a Cluster, but can be converted of course.
Richard
(4,160 Views)
OH, It has to be FAST also. Thanks again.
Richard
(4,159 Views)
Well... you can try this one but it might be faster to roll your own with a for loop.
(4,150 Views)
Use the array max/min from the block diagram array tools.
(4,151 Views)
DOH!
I missed that one.  I've even used it before... Smiley Surprised
What can I say 😃 its a friday
(4,135 Views)
THANKS. All those things start to run together and look the same after a while! Smiley Very Happy Thanks for finding it for me.
Richard
(4,126 Views)
