Find maximum in array inputs
Dear All,
I would like to find and replace the highest value among a set of values being polled.  I only manage to find the highest value if i compare the new value with the old value using a shift register with a single value (element) only.
Right now, if i am dealing with array inputs instead of single value, how should i do it?
Example:
New Input1=[5
                     4
                     3
                     2
                     1]
 Input 2= [  4
                   3
                   5
                   3
                   3]
 Therefore the answer should be  x=  [5
                                                         4
                                                         5
                                                         3
                                                         3]
Then if another new input array has higher values then x, the answer will again be modified.The values are compared by row versus row of each elements in the array. The final answer should be in array form.
Can anyone help out with this? Thank you so much!
Message 1 of 14
(19,340 Views)
One way, this is the first one that jumped to mind. May be an easier one out there.
Message Edited by for(imstuck) on 04-22-2010 10:37 AM
Message 2 of 14
(19,335 Views)
Tim Elsey
Certified LabVIEW Architect
Message 3 of 14
(19,327 Views)
Have you tried the following labview function?
Array Max & Min Function
Message 4 of 14
(19,323 Views)
Dear else and for,
My input is forever polling there so do i need any shift register to keep track of the last highest value array? By the way, can you tell me what functions icon you use, i cant find the icon? Can attach the VI or snippet?
Message 5 of 14
(19,307 Views)
newbieboy wrote:
Dear else and for,
Use Tim's(elset191) solution. It's cleaner. I didn't know it accepted arrays. The function is max& min and is under programming->comparison.
As for your question about the shift register, you would then feed the (max,min) array into a shift register to be compared again next time.
Message Edited by for(imstuck) on 04-22-2010 11:26 AM
Message 6 of 14
(19,294 Views)
Accepted by topic author newbieboy
Tim Elsey
Message 7 of 14
(19,284 Views)
elset191 wrote:
WINNER WINNER, CHICKEN DINNER
Message 8 of 14
(19,280 Views)
Dear Else,
I have attach my VI but i am not sure how come the max (x,y) is all zero?
Please help!
Message 9 of 14
(19,271 Views)
I'm not sure either, I can't open your VI.  I'm using 8.6
Tim Elsey
Message 10 of 14
(19,269 Views)
