Find maximum value of waveforms
Hi
I need to multiply 2 sine waves and find the Maxumim value .I have used array Max and Min function but it is not working as I expected.Would u please help me how can I find the max value
(6,432 Views)
It's not working because you are not passing an acceptable array to the function. You need to use the Get Waveform Components function to get the Y array. No need at all for the build array function.
(6,425 Views)
Hi en99,
As Dennis explained, see the the attached VI Snippet (PNG).
Best Regards,
Christian Hartshorne
NIUK
(6,389 Views)
This may help...
kudos welcome
(6,371 Views)
