Find newest element in 2D array according time
@Jonathan_Rao wrote:
Hi,I attached VI here .Willing to get your proposal.
LV version 2020.
This is now a different problem because you have more than two columns! Which column should be the key? Do you want all column elements at the end?
Message 11 of 15
(590 Views)
See if this works for you.... (Not fully tested, though)
Message 12 of 15
(587 Views)
Of course a lot of simplifications would be possible if we have more information about the data. For example, is the first column always sorted by time? How about the last column?
Message 13 of 15
(580 Views)
Well, your first column is NOT sorted in time, but if we still can assume that for each unique element in the second column, the newest is last, we can still simplify. Here are two possibilities. (all give the same result with your current sample data).
The map version scales better for very large inputs, of course.
Message 14 of 15
(576 Views)
Hi,altenbach
I can not appreciate you more on helping this topic .
This reorder thougts and your snaps helped a lot.
Now I can solve test value reorder issue .
Great work!!!
Message 15 of 15
(562 Views)
