Find out which element is selected in an array
Is there a easy way to find out which element in an array is selected (when I click on an element of an array)?
I can use "ArrElem.Value" of a property node to get the value of the element selected, but I do not know how to get the index number of this element in the array.
Can someone help? Thanks.
Ian
(3,555 Views)
You don't say what dimensions the array is, but the technique demonstrated by yours truly and others on the following thread may be of interest:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000FB7E0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=Display+the+currently+active+cell+coordinates&USEARCHCONTEXT_QUESTION_S=0
(3,555 Views)
Hi Ian,
There are a couple of ways I can think of.
The first is only useful if you know you don't have any multiple entries in the array. You can get the value of the selected cell (over the ArrElem.Value) property, and compare this with all of the vlaues in your array.
The second method should work on any array. You can get the position of the selected cell using the ArrElem.Xposition and Yposition (Text may be different - I have the german version). This, combined with the Height and Width of each cell (also over the ArrElem Property) and the index value of the array (readable from the Array Property node) can be used to calculate the currently selected array. Of course you also need the X and Y coordinates of the array itself when calculating
the offset of the current cell. This is a horrible complicated way to do something simple, but I don't know of any other.
A cheeky way of doing this might be to store the original values of the array and then temporarily "flash" the array with indexed values (0...n) and then read out the value of the current cell before re-instating the original values. If you have large arrays, this is of course not very efficient.
I don't have an example, but if you want I could whip one up.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,555 Views)
Hi, Shane
The "ArrElem.Xposition and Yposition" method worked. I never thought of doing it this way.
Thanks for your help.
Ian
(3,555 Views)
