Find the control named "IMAQdx.ctl"
The list of files that Labview is asking to be found includes:
IMAQdx.ctl
IMAQ image.ctl
IMAQ copy
Image Type
IMAQ ArrayToImage
AviRefnum.ctl
IMAQ AVI Close
IMAQ AVI Write Frame
IMAQ AVI Create
IMAQ Create
IMAQ Overlay Points
IMAQ Overlay Oval
etc
It seems to me as though I am simply missing an installed addon/secondary software which would contain all of these files, however according to my research group advisor, we should have everything we need.
We are supposed to be utilizing the Vision Development Module and other Vision Acquisition software in order to make use of a CCD image of our aparatus, however though we have installed the Vision Development Module and downloaded the .vi given to us by another research group, we are unable to run the program.
Any Advice?
(6,780 Views)
In your Device Driver DVD you should have both IMAQ and IMAQdx, you simply have to install them.
Marco
(6,757 Views)
What version of LabVIEW are you using?  If you installed the Vision Development Module, you should see on the Block Diagram palette "Vision and Motion", which should have a sub-palette called Vision Utilities, with a sub-palette called Image Management that has IMAQ Copy on it.  These palettes will also have many of the other VIs in your list.  This should be the case even if you do NOT have drivers installed (or at least I think that's the case ...).
If you do NOT see this palette in the Block Diagram palette set, assume that you do not have Vision Development Module installed properly.
(6,733 Views)
