Find zero crossing of input data signal in real time
Hi!
I'm trying to find the zero-crossing of function in real-time. Basically I'm reading in some data sampled in real time and want to find the first zero of its autocorrelation. Any ideas?
Thanks!
(3,305 Views)
What version of Real Time are you running?
(3,271 Views)
We are currently using Labview 8.6.
(3,259 Views)
Does the Zero Crossing PtByPt VI, seem like the function you are looking for?
There is also a Community Example that will perform Period Length Measurements using Zero Crossing Method.
If this function is not what you are looking for, please describe your hardware setup and where you are analyzing the data in Real-Time or on the Host VI?
M. Whitaker
ni.com/support
(3,235 Views)
Thanks that should do the trick!
-zporange
(3,232 Views)
