Finding Defect fuse images from set of fuse images
          I am very new to Lab VIEW 8.0 & IMAQ vision.Pls help in my small project.
In the attached zipped folder there are images of electric fuses.
I have to write a LabVIEW program that detects:
1. the broken or damaged fuses in images 7 and 8
2. the orientation (up/down) of the wire in the other images.
regards,
Suresh Kolli
(2,503 Views)
Do you need help with something specific or do you want someone to write you a program?  Are you using NI-Vision Development that is an additional software package that integrates into LabVIEW or just IMAQ portion of LabVIEW?  This is an easy task with the Vision Software.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,489 Views)
