Finding LabView 2013 FPGA Compilation tools
I am unable to compile my program in LabView 2013 using FPGA. The board I am using is NI-sbRIO 9642.
The message pop out said it need a FPGA Compiler. May I know what type of FPGA compiler is suitable to use for NI-sbRIO 9642 board?
Ronald
(3,188 Views)
You could right click on your FPGA target, and click "FPGA Properties". You will then see the page attached below.
For short, NI-sbRIO 9642 is equipped with a Spartan-3 FPGA, which requires Xilinx ISE 14.4 to be installed either locally on your computer or remotely on a compile server.
(3,134 Views)
