Finding a specifici subvi for tktds1k2k
Sorry if this is posted in the wrong place but I was wondering if someone could provide guidance on an easier way to track down an old subvi?
 I have been digging around for a long time trying to find this missing piece called "tktds1k2k read display measurements" to work in this spectra scan 3 program that I have.
I have downloaded drivers to some of the Tektronix oscilloscopes and I find things that are close and a whole instrument library full of things but nothing is the correct piece.  I've attached the program that I am looking for the piece for.
I just wasn't sure if there is an easier way to search for sub vis on here without downloading a ton of random tektronix drivers and installing a ton of stuff just to find once piece.
Thanks for any suggestions.  I've been trying to figure this out for several days.
Actually its more of an issue of finding the entire library for "tktds1k2k.llb".  I have this installed on my computer but the specific subvi is missing.  Maybe there is a complete library that I can download and I haven't been able to locate that yet?
(829 Views)
The current drive Read Measurements.vi is likely to have the same functionality.   You are almost assuredly better off porting to the newer driver.
Tek had a notoriously slow learning curve when they originally started sourcing LabVIEW Drivers.  They did eventually get good ones out but, older revisions were essentially obsoleted.  The name suggests to me that it's part of an old llb style driver.
(823 Views)
