Finding an xcontrol
If i open a VI without the use of a Project and the VI contains an XControl how do I:
A) Know that the control I'm looking at is an Xcontrol ?
and
B) Navigate to the *.xctl file in order to make changes to this XControl?
For example, open the "Run Dual Mode Thermometer XControl.vi". I have no way of knowing the controls used in this example are XControl nor can I find a path or navigate to the *.xctl file
Thank you!
Craig
(2,755 Views)
On the Control or Terminal you can Right-Click -> Advanced -> Show Diagram to see the XControl Facade.  From the Facade you can View -> Browse Relationships -> This VI's XControl.
To know it is an XControl you can use Icon view for the terminals, or View the Hierarchy to find all instances of the selected XControls.
(2,748 Views)
