Finding angle between two center points (vision)
Hi all,
   1.  i found a centre points two circles (x1,y1) and (x2,y2) . .. so i need to find the angle between these two points ,. i have used atan((y2-y1)/(x2-x1)) it is rad then i converted into deg..
   2 . the calculated degree -87 i am getting negative degree..
but in Vision assitand i am able to get 270 degree .. everything is perfect ..
please help me to get solution for this .
(4,052 Views)
Hi saran,
you know you can add 360° to your ~-90° to get your desired ~270°?
Simple math, eh!
(4,041 Views)
Yes I did that .. is it possible to without doing 360 - 90
(4,038 Views)
Hi saran,
as atan is only defined in interval (-pi/2, +pi/2) you will always get results in range -90…90°.
Basic math knowledge, don't you think?
(4,031 Views)
(4,029 Views)
Hi saran,
you aren't familiar with popular knowledge databases like Wikipedia?
Reading the LabVIEW help is also a great source of wisdom… Wow, it also links to an example VI in the example finder!
(4,027 Views)
