Finding references and local variables of Clusters
Hi, I am working on someone else's Labview Code which means I have to do a lot of finding and searching. I have a bunch of Clusters and I can't right click>> Find>> local variables/ reference for my clusters as the option is not available. Is there a setting I need to enable to be able to do this or is there another way to search for the local variables and references from Clusters??
(1,508 Views)
Accepted by topic author VBajaj
OKay I've figured it out. PLease delete this post.
(1,505 Views)
Since this is a self-help forum, could you please explain how you solved your problem?  It doesn't help other people if you mark your post as a solution and then just say that you figured it out.
Thanks.
Bill
CLD
(Mid-Level minion.)
(1,452 Views)
