Finding subfolder
I have about 2000 subfolders, all named "subfolderXYZ", in a file structure.  I want to find the paths to all those subfolders, and then I will find the path of file with latest timestamp in these subfolders.  Is there a VI out there that I can use, or should I start writing the VI?  Anything similiar to get me started would be nice.  Thanks!
Kudos and Accepted as Solution are welcome!
(4,688 Views)
Recursive File List
(4,676 Views)
I plan to use that vi.  I was just wondering is there anything out there there is already made.  I guess I will start coding.
(4,640 Views)
Also, that VI takes a over a min to run on my file structure.
(4,638 Views)
Hi jyang,
what do you expect with a file structure like yours with 2000 subfolders and maybe several files per folder? Without using a cache it takes some time to check file properties for each file…
(4,632 Views)
That VI IS "already made"!
(4,627 Views)
How long does it take to manually traverse all files and folders in Windows Explorer?
The VI is already made and it is open so you can save a copy of the recursive file list VI somewhere else, then modify it to improve speed.  There maybe features you don't need and can remove to improve speed.  It didn't sound like you cared about the files so keeping a huge array of all the files found might not be needed and removing it could improve performance.
(4,623 Views)
