Finding the minimum number greater than zero in an array
can i kw wat is the function used within d case structure,,,,
Message 11 of 27
(3,141 Views)
Max & Min (found in the comparison palette)
Message 12 of 27
(3,132 Views)
For completeness, here's the first method I suggested earlier:
If we know that all the numbers are positive, then we don't need the case. Like I said, this is more about simple code and less about efficiency. To determine the most efficient method, we would need to know what actual typical data looks like. I'm sure Altenbach can pick apart the various versions for all their performance characteristics.
___________________
Try to take over the world!
Message 13 of 27
(3,127 Views)
Has he done this before? Smiley Tongue
Message 14 of 27
(3,105 Views)
amitai.abramson,
The numbers can be integers but NOT necessarily always so.
The shape of the array will not always be the same, it keeps changing.
Hope this clarifies.
Knights solution does the trick for all I have so far tried. There can be other solutions of course.
Message 15 of 27
(3,101 Views)
Just so you know, "Knight of NI" is a forum title.  His screen name is "Altenbach".
Message 16 of 27
(3,096 Views)
 ... and it got significantly more ambiguous this week! 😄
Message 17 of 27
(3,090 Views)
Between the newly knighted knights and @Ranjeet_Singh it's hard to keep all you guys straight.
Message 18 of 27
(3,083 Views)
So....
After finding out that the values datatype is not always an Integer,I have tried some stuff ...
you guys got this working just fine.
yet, feel I should share the same/different ways I found, feel free to comment.
1. (disregarding Performance, looks short)
    I found out the Array Max & Min function disregards NaN.
    I followed tst's way of thinking to turn the zeros to NaN by
    subtracting epsilon from the 2D array and then performing Square Root on the result.
    That action created a new array, with NaN instead of zeros and all the of the non-zero (positive) numbers remain
    relatively big or small from one another the same as in the original 2D array.
    So now we can use the Array Max & Min function safely to find the indexes of the Min,
    and also the Min Value (up to the power of 2)
2. (very close to what altenbach did)
     Creating a subVI similar to what
Message 19 of 27
(3,072 Views)
In your code for 1. you should add epsilon to the minimum value after squaring.  If the minumum value in the original array was epsilon, then minimum output value would be reported as zero.
Lynn
Message 20 of 27
(3,067 Views)
