Finding tunnels with defaulf values set
Is there a way to find all the tunnels (present in any VI belonging to a project) which are passing out default values?
(2,591 Views)
I almost always avoid using tunnels that use defauld values since this can cause difficult debugging issues (add new case and maybe the default is not what you wanted).  Best I can suggest it that you can do a find on case structures, then unselect use default, this will break your code, then find errors will take you to the case that uses the case structure.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,588 Views)
Probably with VI Analyzer Toolkit? (but not sure)
Andrey.
(2,573 Views)
