Firefox Plugin x-labviewrpvi for SunFire X4200 (x86-AMD/Sol 10)
I wonder if there is x-labviewrpvi plugin for Firefox on a SunFire X4200 (x86-AMD/Sol 10). We are imgrating our  web-based labview application from Blade 150 (Sparc) Solaris 8.
(3,233 Views)
Hello vivision,
In my initial search both online and on our server, I was not able to find the plug-in for Solaris 10. I will address the question to some colleagues and get back to you tomorrow.
Thank you,
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(3,212 Views)
Hello vivison,
Can you give a bit more info on the bigger picture of your application and where the plug-in fits in? Are you using web services on the Solaris to publish the VI to the web or are you just accessing the remote panels from it? If accessing, you’ll need to have the same Run-Time Engine as the version of LabVIEW with which you created the VI.  If there isn't a version of the Run-Time Engine compatible with the new Solaris 10, it may not be possible.
Deborah Y.
Deborah Burke
(3,197 Views)
