Firewire camera does not show up in MAX but works in Labview
Hello! Today we used our firewire camera with the use of MAX (2.2.0). A few hours later it did not show up in the MAX but it worked if I used a labview program. Uninstalled and reinstalled MAX but it is the same problem. Can someone give me a hint how to solve it.
(2,698 Views)
This is probably an installation problem. If the 1.5 driver installed properly, you should find the file imacfgui.mxs in the following directory: Program Files>>National Instruments>>MAX>>UI Providers. If this file doesn't appear, the installation did not complete successfully. One easy solution that typically works is to search for the IMAQCFG.msi on the installer CD. If you run this, it should fix the problem. If this still fails, go through the complete reinstall.
(2,696 Views)
