First LabView program for application
I am very new with LabView and am trying to create my first program for my application. I have created a flowchart to make it easier for me to know what my program will need as well as made a list of the inputs and outputs for my application. However, I am unsure how to go from there. Are there any tips or advice on how to start building the program after completing a flowchart?
I do not have any hardware and I'm hoping to use a simulated device for my application but I can't seem to find many examples of code that just use simulated devices.
I'd appreciate any help!
(2,834 Views)
What kind of application you want to develop?
(2,808 Views)
I am a senior mechanical engineering student and my application is for my senior design project. I don't have the ability to disclose all the information but the application is a particle plugging apparatus that will measure the differential pressure of the drilling fluid flow as it moves through the test cell to determine if it is plugging.
(2,786 Views)
Maybe you can try to explore some basic LabView function from below link:
http://www.ni.com/getting-started/labview-basics/
From there, maybe you have idea how to start develop your application by LV.
(2,764 Views)
Thank you, I appreciate your help! I will check it out.
(2,754 Views)
