First-Order Linear Inhomogeneous Differential Equation
Hello to Math pros.
I need to simulate a preamplifier output when it reads a single current pulse.
The theory says that the preamp output voltage can be solved with the following equation:
dV/dt = I(t) / C - V/RC,
where V(t) is Voltage we are solving for. I(t) is the known current function that I have in a 1D array t0=0 and time step = 0,01 ms (it's already calculated), it looks similar to a gaussian pulse with the maximum at, say, 2 millisecond from start. C and R are the known constants of the preamplifier circuit (capacitance and resistance).
I have not looked at differential equations in quite a while. I believe this equation is a First-Order Linear Inhomogeneous Differential Equation.
Does anybody know how to solve for V(t) in this case in labview? Perhaps there is an example one can look up?
Thanks in advance!
Message 1 of 1
(2,171 Views)
