First Values Keep Replacing Old one despite file position set
I have saved to file and I have used the save to file function.
It works well and for each run I have 6 values, however on the second run there, the first new value replaces the old first value but others work well.
What can I do?. I set the position to end for each value collected.
Message 1 of 8
(3,993 Views)
It's impossible to debug a paragraph.
Try attaching your VI.
Message 2 of 8
(3,986 Views)
I attach the VI.
Message 3 of 8
(3,975 Views)
Accepted by topic author concacid
I think you would benefit greatly from looking at the LabVIEW tutorials.
A few things right off the bat:
Try and get away from using Stacked Sequences to repeat code. You'll do much better with a state machine or by using a subVI.
Don't use a local variable for the FileRefnum. Use the wire itself.
Message 4 of 8
(3,958 Views)
Thanks.
I know how to use a state machine but then this is a relatively simple program and runs peferctly but for the svaing option.
I would trying using the wire for the file refnum
Message 5 of 8
(3,956 Views)
Hi concacid,
even for this "relatively simple" program you should THINK DATAFLOW and use wires in favor of local variables…
In your case an autoindexing loop for your 6 channels would be ok too!
That being said:
- Using file refnums should append writes at the end of the file. Please test this after replacing all "refnum out" variables by wires.
- When you insist on using SetFilePosition you should set the write position before doing the actual write, not afterwards. Seems more logical to me…
Message 6 of 8
(3,950 Views)
@GerdW wrote:
Hi concacid,
Thank you!
Points noted
Message 7 of 8
(3,933 Views)
The state machine and 'all wires' did the trick.
Scrap the local variable then. Its more or less useless.
Thanks guys
Message 8 of 8
(3,917 Views)
