First call?
Why is the "First call?" object limited to the top level block diagram in LV6.02?  Is it non-re-entrant?  It is so much handier than playing games with flags.
Jim
LV 2020
(2,751 Views)
You're optimistic expecting an answer about something that happens in LV 6. Smiley Very Happy
As I'm sure you can see in your other versions, there you can place it anywhere you want. I never used that version, so I can't say I know the behavior you're talking about. I suppose you can try wrapping it in a reentrant VI. That way, it should be in the top level diagram and you can place that VI whereever you want.
___________________
Try to take over the world!
(2,748 Views)
