First click and Second click on START
Hello guys :),
I am coming back for you.
I have simplified my worries in this vi below. I have a control START/STOP
What I want to do:
First click on START Camera 1 is visible
Second click on START Camera 2 is visible.
How do I do this? Without using Labview's "first run".
Thanks in advance.
Sincerely
(1,162 Views)
After the second click, should both cameras be visible?
What should happen on the third click?
What about camera 3?
(1,155 Views)
Hi @altenbach,
Good questions.
Après second click toutes les deux caméras visibles oui.
For camera 3 I'm back to doing what I want. Forget it.
In fact I want all even numbers of clicks to do the same thing and all odd numbers of clicks to do the same thing.
Because in my application, this action is repeated for each scenario.
(1,147 Views)
If you only have two states (odd, even), should camera 2 be visible when the program starts? Else you have three states.
  1. 1&2 invisible
  2. 1 visible
  3. 1&2 visible
(1,134 Views)
Hi @altenbach ,
Thanks you for your reply.
No,  camera 2 is not visible when the program starts.
Sincerly
(1,126 Views)
Accepted by topic author Ngouda
See if this can give you some ideas
Run: only #3 visible
press once: 1&3 visible
press again: 1,2&3 visible
press again: 1&3 visible
etc.
(1,122 Views)
Hi @altenbach,
Thanks you very much for your help.
I am going to take this exemple and adapt it for my application.
(1,114 Views)
