Fit Airy (Stokes) function to data
Hi, I've got results in the form of an image from some optical interference experiments that I strongly suspect follows an Airy-function. Has anybody got a VI that finds the best fit coefficients using something like a least square fit for an Airy function?
The signal has (as usual) a saturated centre peak with weaker sidelobes, so if it is an Airy function, it is of type Bi.
Cheers,
Mattias
Message 1 of 1
(1,418 Views)
