Fit a line into a circle based on centrepoint and angle in degrees
Hi everyone,
I want to fit a line based on two values I got , the centre (x,y) and the angle in degrees from the top of the circle, is this possible? (see the attached picture for more clarification)
Message 1 of 9
(3,976 Views)
Accepted by topic author henk_kempen
Sure, just draw a line from (x,y) to (x+radius*cos(angle),y+radius*sin(angle))
Angle needs to be in radians (so angle=2*pi*angle in degrees)
In fact you probably need to faff about a bit to get the angle as you defined it, so in the top equation I think it would actually be (90-angle) in place of angle. Try it and see what it does.
Message 2 of 9
(3,947 Views)
Thanks, I will give it a try!
btw, you said:
... to faff about a bit...
What does that mean (I'm from the netherlands and don't speak english very good:))
Message 3 of 9
(3,938 Views)
doesn't matter, it worked perfectly!! many thanks!
Message 4 of 9
(3,926 Views)
Angle needs to be in radians ( that didn't work with your way, i did it by divide the degrees with 180 and multiply it with pi)
Message 5 of 9
(3,889 Views)
There are also "degree to radians" and radians to degrees" functions on the pallette somewhere. I usually locate them with the quickdrop (ctrl+space), they're just already-filled expression nodes, but they save you some time...
EDIT: Programming -> Numeric -> Scaling
Jarle Ekanger, MSc, PhD, CLD
Flow Design Bureau AS
- "The resistance of wires in LabVIEW is not dependent on their length."
Message 6 of 9
(3,879 Views)
I don't have it in Labview, probably It's a function in newer labview (I use 2010 fall)
Message 7 of 9
(3,867 Views)
Message 9 of 9
(3,721 Views)
