Fit objects in tab control in a lower screen resolution
Hello to all.
Thanks for helping me.
I have developed an application in a laptop of 15.6 inches.
Now I am creating a .EXE to deploy in a PLC of 15 inches.
All my front panel is a tab control which has controls and indicators inside.
The problem is that when I deploy de application I can not see a part of tab control (15 inches vs 15.6 inches).
How can I fit tab control to 15 inches easyly?
Thanks a lot.
(3,539 Views)
Hi A.,
design your FP for the smaller resolution.
Making a FP bigger (by allowing bigger graphs etc.) is much easier then to make it smaller!
Btw. numbers like 15.6"/15" are irrelevant here. All that counts is the screen resolution you can use: on a Windows desktop you should also look for the size and position of the taskbar…
(3,518 Views)
Thanks for replaying!
So maybe if I change resolution of PC 15inches it look good.
btw. If I develop front panel for lower resolution how can I fit it to higger resolution easyly?
(3,509 Views)
Accepted by topic author A.Salcedo
Hi A.,
you can use splitters in your front panel to separate it into sub-parts called panes. For each pane you can decide the behaviour in case the FP window size changes. And when placing controls/indicators in those panes you can also define their behaviour regarding automatic size adaption with FP window size…
Point is: design your FP to look good at the smallest screen resolution you need to support. For automatic adaption to bigger resolutions use splitter bars.
(3,504 Views)
If I use splitter bars then objetcs (indicators, graphs...) are getting bigger or smoller acording the splitter bar?
Thanks!
(3,500 Views)
Hi A.,
objetcs … are getting bigger or smoller acording the splitter bar?
Yes, depending on your scaling settings.
(3,494 Views)
