Fitting Package (Fit Function) - Please help!
Hey I'm a noob and I want someone to explain or give me links or just any info regarding:
Fitting Package (Fit Function) - If anyone knows anything about thise please tell me!
Thanks in advance!
(3,315 Views)
I am not sure what Fitting Package you are referring to.  In general, if you are looking for resources to study curve fitting (which I presume is the functionality underlying the Fitting Package you mention), you may want to look at the following site:
Google is bound to return some useful results by searching relevant keywords as well!
I hope this helps and best of luck!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,297 Views)
THANK YOU VERY MUCH JLS!
(3,281 Views)
No problem, if it was indeed helpful, and if you have any questions about LabVIEW with respect to curve fitting, definitely repost!  Also, if you can post what the fitting package is here, perhaps it will help others who may read this post in the future!
Thank you,
Best Regards,
JLS
Best,
JLS
Sixclear
(3,270 Views)
