Fitting an Optimal Curve and Finding Variables
Thanks so much Darin.  I will try that now.
Message 21 of 23
(942 Views)
For some reason providing the partial derivatives produces worse (this is based on the results I have from the gradient descent method) answers.
I'm sure the partial derivatives have been derived correctly.
Message 22 of 23
(919 Views)
If you are certain the partial derivatives have been derived correctly I would double check that they have been implemented correctly.  Each one should have its own while loop for example.
I was dubious so I added the partials to my fit and got no difference from the results using finite difference approximations.
Message 23 of 23
(883 Views)
