Fitting two datasets to two different models with common parameters
Hello! I need to fit two datasets simultaneously to two different models, which have common parameters. Both of the data sets have the same x-values, but different y-values.
Can anybody help me with the problem?
Thanks!
(2,523 Views)
You can put two copies of the curve fitting VI on your block diagram.  Wire the same X values to both.  Put the apprpriate Y values with the corresponding model.
This seem pretty obvious, so I probably misunderstand your problem.  Post your VI along with some typical data and the expected results.
Lynn
(2,521 Views)
Here is an old example I think does what you want.  The two curves are exponentials (a*exp(b*x)+c) and share the b parameter.  Both curves have the same X values.
-Jim
(2,502 Views)
