Fix LabVIEW Code generation failed to execute
I'm using LabVIEW 2011. I try to use DAQmx assistance to generate one pulse signal from my USB 6259. LabVIEW popped out an error message "LabVIEW Code Generation failed to execute"
I try to reinstall LabVIEW 2011, but the error is still there. Please help
Message 1 of 19
(24,006 Views)
Try repairing NI DAQ.  The driver may have gotten corrupted.
Message 2 of 19
(23,996 Views)
I re-install DAQmx. but the problem is still there.
Message 3 of 19
(23,986 Views)
Hello JimSI,
Did you follow the next steps?
  1. Remove LabVIEW 2011 and NI-DAQmx from your computer
  2. Install LabVIEW 2011
  3. Install NI-DAQmx 9.6.1
Message 4 of 19
(23,965 Views)
Accepted by topic author JimSi
Problem is gone after re-install LabViEW and DAQmx.
thanks
Message 5 of 19
(23,947 Views)
Hi All:
Same problem here.
LabVIEW 2012 64-bit
NI MAX 5.5
Failed to execute LabVIEW Code Generation after configuring Express VI for Data Acquisition.
Academic Site License... IT has installed over network.
I'm guessing the fix a wipe and reinstall?
Thanks!
Message 6 of 19
(23,797 Views)
Hi williamlweaver,
You can try the steps above or you could try force reinstalling over your current installs.  Make sure to force reinstall LabVIEW before you force reinstall DAQmx.  Here is a Knowledgebase article on force reinstallation of our products;
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwJCAW&l=en-US
Peter T
Message 7 of 19
(23,771 Views)
Thanks, Peter T!
I will give it a go with our IT department and report back here.
We've been using LabVIEW in our teaching labs since 2000 and this is the first time we've run into the problem.
Thanks for the quick reply,
-Bill  =]
Message 8 of 19
(23,762 Views)
I have been getting exactly this problem with the 'LabVIEW code generation failed' message, but with LabVIEW 2017 and DAQ 19.6.  Allowing for this being an old thread, does anyone have a better solution to the DAQ problem than the drastic, uninstall and reinstall everything option?
         Ian
Message 9 of 19
(21,823 Views)
FYI, I got the same problem as you with LabVIEW 2020 and Max 20.5.  All I do is use the "repair" option in "Programs & Features" instead of uninstalling the whole NI package.  It fixed.
Message 10 of 19
(20,560 Views)
