Fixed number of major tick marks
Is it possible to make the number of major tick marks on a waveform graph fixed?
I have multiple scales and I want the tick marks on these to correspond with one grid. I've locked the number of gridlines, and now I wonder if it is possible to write some sort of code making the number of tick marks fixed? Thx!
(3,332 Views)
You can use the properties of the graph to set the number of major and minor tick marks (X Scale->Range->Minimum, Maximum, Increment, Minor Increment).  In older versions of LabVIEW, you may have to do this every time you write new data to the graph.  I don't know if this bug has been fixed.  Make sure you turn autoscaling on that axis off.  If you have more than one X axis, you will need to set Active X Scale before setting the Range values.
If you need more help, let us know.
(3,299 Views)
