Fixing digital display of a chart
Dear Community Members,
Hope you are doing well. Please check the image below. I turned on digital display but it always show 0.00 as current value. I feel like as the value is around 10E06 to 10E-11 range that's why it is converting the values to zero. Is there any way to specify the data type here? For example, %.10f might solve the problem.
Thank you
(815 Views)
Accepted by topic author Jarir
Right click the Digital Display, on the popup menu, select "Display Format..."
George Zou
(795 Views)
