Flash FPGA lvbitx
Hi !
Thank you for the precision, I'm trying to do it by RIO Device Setup (according to this paper https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9mASAS&l=en-US) but the "Device Settings" tab is not accessible... I can't click on it. I tried with administrator permissions but it's the same, to launch the RIO Device Setup from MAX, with or without a VI already flashed but it's the same again... I'm a bit confused to ask you your help again...
Thank you !
Afghow.
Message 11 of 12
(982 Views)
That is deliberate, myRIO (and other Zynq targets) don't support the device settings tab. Due to the fact that the FPGA is cleared on every reset, it didn't make sense to distinguish between "Autoload on Powerup" and "Autoload on Reset". If a bitfile is downloaded, it will be autoloaded. If you wish to stop a bitfile from being autoloaded, you can either use the Disable FPGA Startup App soft switch in MAX/WIF for a temporary solution or erase the bitfile for a more permanent solution. I know we documented this in the help for the cRIO-906x controllers (https://www.ni.com/docs/en-US/bundle/compactrio-controller-and-chassis-reference/page/cserieshelp/ni... but I can't seem to find a similar note in the myRIO documentation.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9uiSAC&l=en-US also has some more information on this topic.
Message 12 of 12
(967 Views)
