Flash Programming using NEC PG-FP5
I have try to use hyperterminal to comunicate with NEC PG-FP5 but I don't receive any response from programmer. Can you help please with some information? What you send first time to the programmer, I have try with cariage return ar other commands but nothing. There is somewere a list with all the sequense that I must send in order to program a microcontroller?
Thank you.
Bogdan
Message 11 of 14
(1,789 Views)
FP5 with Hyper Terminal works fine, but does anyone know how to send command to FP5 through VISA properly?
I tried first with MAX, but no progress.
Thank you.
Message 12 of 14
(1,737 Views)
Found out a way and its working perfect.
Issue was in settings: Baud rate (by default 9600) and Flow control
Message 13 of 14
(1,728 Views)
Guys,
Can I have the FP5 flash.vi ‏21 KB to open in labview 2012?
Message 14 of 14
(1,400 Views)
